Einleitung
The scanner head is necessary for copying and faxing. Follow the guide to replace this crucial part.
Was du brauchst
Peel the model sticker off the cover.
This will expose the T10 screw securing the panel.
Remove the single 12mm-T10 screw securing the front panel to the printer body.
Loosen the panel cover from the printer body.
Remove the seven 8mm screws using the Torx T6 screwdriver.
Remove the motherboard from the front-panel housing.
Start with the scanner head in place.
Unwind the ribbon from the track.
Detach ribbon completely.
