Zum Hauptinhalt wechseln
HP Officejet 4630 Scanner Head Replacement
Was du brauchst
  1. HP Officejet 4630 Scanner Head Replacement, LCD Display: Schritt 1, Bild 1 von 3 HP Officejet 4630 Scanner Head Replacement, LCD Display: Schritt 1, Bild 2 von 3 HP Officejet 4630 Scanner Head Replacement, LCD Display: Schritt 1, Bild 3 von 3
    • There is a hidden screw underneath the model sticker on the front panel.
    • Peel the model sticker off the cover.
    • This will expose the T10 screw securing the panel.
  2. HP Officejet 4630 Scanner Head Replacement: Schritt 2, Bild 1 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 2, Bild 2 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 2, Bild 3 von 3
    • Remove the single 12mm-T10 screw securing the front panel to the printer body.
    • Loosen the panel cover from the printer body.
    • There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
  3. HP Officejet 4630 Scanner Head Replacement: Schritt 3, Bild 1 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 3, Bild 2 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 3, Bild 3 von 3
    • Gently remove the No-Fuss ribbon cable from the front panel.
  4. HP Officejet 4630 Scanner Head Replacement: Schritt 4, Bild 1 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 4, Bild 2 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 4, Bild 3 von 3
    • Remove the seven 8mm screws using the Torx T6 screwdriver.
    • Remove the motherboard from the front-panel housing.
    • The LCD display is on the opposite side.
  5. HP Officejet 4630 Scanner Head Replacement, Power Supply: Schritt 5, Bild 1 von 3 HP Officejet 4630 Scanner Head Replacement, Power Supply: Schritt 5, Bild 2 von 3 HP Officejet 4630 Scanner Head Replacement, Power Supply: Schritt 5, Bild 3 von 3
    • Lift the hood of the printer.
  6. HP Officejet 4630 Scanner Head Replacement: Schritt 6, Bild 1 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 6, Bild 2 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 6, Bild 3 von 3
    • Remove the two T10 11mm screws.
  7. HP Officejet 4630 Scanner Head Replacement: Schritt 7, Bild 1 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 7, Bild 2 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 7, Bild 3 von 3
    • Remove the panels covering the power brick and cord.
  8. HP Officejet 4630 Scanner Head Replacement: Schritt 8, Bild 1 von 2 HP Officejet 4630 Scanner Head Replacement: Schritt 8, Bild 2 von 2
    • Remove the cord from the power supply.
  9. HP Officejet 4630 Scanner Head Replacement: Schritt 9, Bild 1 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 9, Bild 2 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 9, Bild 3 von 3
    • Slide the power supply out from the chassis.
    • The power supply is still attached; don't pull too quickly.
  10. HP Officejet 4630 Scanner Head Replacement: Schritt 10, Bild 1 von 1
    • Remove final cable from power supply.
  11. HP Officejet 4630 Scanner Head Replacement, Scanner Head: Schritt 11, Bild 1 von 1
    • Remove eight T10 1mm screws from the top hood of the printer.
  12. HP Officejet 4630 Scanner Head Replacement: Schritt 12, Bild 1 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 12, Bild 2 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 12, Bild 3 von 3
    • Use the nylon spudger to pry the tab.
    • Lift up the entire panel.
  13. HP Officejet 4630 Scanner Head Replacement: Schritt 13, Bild 1 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 13, Bild 2 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 13, Bild 3 von 3
    • Lift and flip the entire panel.
    • Be aware of the scanner head attached to the panel.
  14. HP Officejet 4630 Scanner Head Replacement: Schritt 14, Bild 1 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 14, Bild 2 von 3 HP Officejet 4630 Scanner Head Replacement: Schritt 14, Bild 3 von 3
    • Start with the scanner head in place.
    • Unwind the ribbon from the track.
    • Detach ribbon completely.
Abschluss
Maya Willis
415 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S18-G3, Livingston Winter 2018 Mitglied von Cal Poly, Team S18-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G3
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 1,396
