Einleitung
Is the paper not coming out of your printer correctly? Consider using this guide to replace the paper feed roller in your printer.
Was du brauchst
Open the document feeder cover by flipping it to the left with the front panel facing you.
Locate the manual paper-feed roller end of the document feeder cover.
Remove the 10mm screw on the side of the roller with T8 torx security screwdriver.
Pull the side cover of the paper-feed roller to the right and remove the paper roller.
