Zum Hauptinhalt wechseln
HP Officejet Pro 6835 Speaker Replacement
Was du brauchst
  1. HP Officejet Pro 6835 Speaker Replacement, HP Officejet Pro 6835 Cover Disassembly: Schritt 1, Bild 1 von 1
    • Open the main lid as far as it will go.
    • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
    • Open the lid further.
  2. HP Officejet Pro 6835 Speaker Replacement: Schritt 2, Bild 1 von 3 HP Officejet Pro 6835 Speaker Replacement: Schritt 2, Bild 2 von 3 HP Officejet Pro 6835 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
    • The two screws above the screen assembly are deep so you may need a long screwdriver.
  3. HP Officejet Pro 6835 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Grab the main cover and lift it up slightly.
    • Do not pull too hard—there is a cable connecting the cover to the printer.
  4. HP Officejet Pro 6835 Speaker Replacement: Schritt 4, Bild 1 von 2 HP Officejet Pro 6835 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
  5. HP Officejet Pro 6835 Speaker Replacement, Speaker: Schritt 5, Bild 1 von 3 HP Officejet Pro 6835 Speaker Replacement, Speaker: Schritt 5, Bild 2 von 3 HP Officejet Pro 6835 Speaker Replacement, Speaker: Schritt 5, Bild 3 von 3
    • Grab the intertwined red and black wires. Gently pull up and disconnect the wires from the motherboard.
    • Be careful to remove the wires from the socket, NOT the socket from the board.
  6. HP Officejet Pro 6835 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Carefully slide the speaker out of the printer.
Abschluss
David J
169 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S2-G4, Livingston Winter 2018 Mitglied von Cal Poly, Team S2-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G4
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 288
