Einleitung
After consistent use the printer speaker can stop working. This guide will go over how to change out the speaker at the front of the printer.
Was du brauchst
Open the main lid as far as it will go.
Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
Open the lid further.
Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
Grab the intertwined red and black wires. Gently pull up and disconnect the wires from the motherboard.
