Einleitung
The front panel door may not close properly after repeated use. This guide will show how to remove the front panel door.
Was du brauchst
Open the front panel door by pulling forward on the slot located on the front-left side of the printer.
Insert the plastic opening tool into the right socket connecting the front panel door to the hinge guide.
Pry the socket open, lifting the door hinge guide out of place.
Pull the door-hinge guide to the right to detach its left socket.
Lift the door-hinge guide upward and away from the front panel door.
Grab the front panel door close to its hinge on the right side.
Pull the front panel door away from the printer toward you.
Grab the front panel door close to its two hinges on the left side.
2 weitere Personen haben diese Anleitung absolviert.
