Zum Hauptinhalt wechseln
HP Officejet Pro 8620 Power Adapter Replacement
Was du brauchst
  1. HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: Schritt 1, Bild 1 von 3 HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: Schritt 1, Bild 2 von 3 HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: Schritt 1, Bild 3 von 3
    • Turn off the printer and remove the power cable.
    • Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
  2. HP Officejet Pro 8620 Power Adapter Replacement: Schritt 2, Bild 1 von 2 HP Officejet Pro 8620 Power Adapter Replacement: Schritt 2, Bild 2 von 2
    • Open the front door by placing your finger on the indented groove on the left side of the printer and pulling down
    • This will give you access to the two T9-TORX 13mm screws that need to be removed to release the panel.
  3. HP Officejet Pro 8620 Power Adapter Replacement: Schritt 3, Bild 1 von 2 HP Officejet Pro 8620 Power Adapter Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 13mm screws with a T9-TORX screwdriver by turning counter-clockwise (left).
  4. HP Officejet Pro 8620 Power Adapter Replacement: Schritt 4, Bild 1 von 3 HP Officejet Pro 8620 Power Adapter Replacement: Schritt 4, Bild 2 von 3 HP Officejet Pro 8620 Power Adapter Replacement: Schritt 4, Bild 3 von 3
    • Gently remove the left side panel by placing your palm flat against the surface and pulling down.
  5. HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: Schritt 5, Bild 1 von 3 HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: Schritt 5, Bild 2 von 3 HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: Schritt 5, Bild 3 von 3
    • Remove two screws 13mm screws with a T9-Torx screwdriver by rotating them counterclockwise.
  6. HP Officejet Pro 8620 Power Adapter Replacement: Schritt 6, Bild 1 von 3 HP Officejet Pro 8620 Power Adapter Replacement: Schritt 6, Bild 2 von 3 HP Officejet Pro 8620 Power Adapter Replacement: Schritt 6, Bild 3 von 3
    • Unplug the black cable .
    • Move all the cables and wires to the top of the motherboard to allow the power adapter underneath to be removed freely.
  7. HP Officejet Pro 8620 Power Adapter Replacement: Schritt 7, Bild 1 von 1
    • Gently bend the black ribbon cable.
    • Remove one 8mm T8 screw underneath the ribbon cable by rotating it counterclockwise with a T8 -Torx screwdriver.
    • Take out the black plastic cover and the colored wires connected to it.
    • Now you have cleared a passage for the power adapter to be taken out.
  8. HP Officejet Pro 8620 Power Adapter Replacement: Schritt 8, Bild 1 von 1
    • Gently pulling out the power adapter.
    • Be careful with all the wires when pulling out the adapter.
Abschluss
Scott
593 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S19-G2, Livingston Spring 2018 Mitglied von Cal Poly, Team S19-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S19G2
1 Mitglied
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 25
Insgesamt: 2,225
