Zum Hauptinhalt wechseln
HP Officejet Pro 8625 Motherboard Replacement
Was du brauchst
  1. HP Officejet Pro 8625 Motherboard Replacement, Left Side Panel: Schritt 1, Bild 1 von 3 HP Officejet Pro 8625 Motherboard Replacement, Left Side Panel: Schritt 1, Bild 2 von 3 HP Officejet Pro 8625 Motherboard Replacement, Left Side Panel: Schritt 1, Bild 3 von 3
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. HP Officejet Pro 8625 Motherboard Replacement: Schritt 2, Bild 1 von 3 HP Officejet Pro 8625 Motherboard Replacement: Schritt 2, Bild 2 von 3 HP Officejet Pro 8625 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. HP Officejet Pro 8625 Motherboard Replacement: Schritt 3, Bild 1 von 2 HP Officejet Pro 8625 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
  4. HP Officejet Pro 8625 Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 3 HP Officejet Pro 8625 Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 3 HP Officejet Pro 8625 Motherboard Replacement, Motherboard: Schritt 4, Bild 3 von 3
    • Remove the three 5.3 mm T9 screws from the motherboard.
    • Remove the one 6.7 mm T9 screw from the motherboard.
  5. HP Officejet Pro 8625 Motherboard Replacement: Schritt 5, Bild 1 von 2 HP Officejet Pro 8625 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the connectors from the front and sides of the motherboard by pulling straight away from the connection.
  6. HP Officejet Pro 8625 Motherboard Replacement: Schritt 6, Bild 1 von 3 HP Officejet Pro 8625 Motherboard Replacement: Schritt 6, Bild 2 von 3 HP Officejet Pro 8625 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Lift the bottom of the motherboard and remove the connectors from the back.
    • Remove the motherboard.
    • There are two white connectors underneath the motherboard, remove them separately.
Abschluss
Cam Engle
531 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S13-G3, White Fall 2018 Mitglied von Cal Poly, Team S13-G3, White Fall 2018
CPSU-WHITE-F18S13G3
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 12
Insgesamt: 484
