Einleitung
The printhead holds the ink cartridges and is responsible for the motions that actually print documents onto paper. If you receive error messages stating that the printhead is missing or failed, use this guide to replace it. You will need a T9 Torx screwdriver for all of the screws in this guide.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the two 11.6 mm T9 screws from the right side of the back of the printer. Remove the two 11.6 mm T9 screws from the right side of the back of the printer. Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. Pull down the front panel to expose the screws on the front. Remove the one 11.6 mm T9 screw on the left side of the front face. Remove the one 11.6 mm T9 screw on the left side of the front face.
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. Remove the side panel by pushing down and towards the back. This step may be easier if the printer is laid on its side with the left side panel facing up.
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
  4. Remove the one 5.3 mm T9 screw. Remove the one 5.3 mm T9 screw.
    • Remove the one 5.3 mm T9 screw.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Remove the four connectors from the top of the motherboard. Remove the four connectors from the top of the motherboard.
    • Remove the four connectors from the top of the motherboard.
  7. Remove the three 11.6 mm T9 screws from the top, back of the printer. Remove the one 12.1 mm T9 screw from the top, back of the printer.
    • Remove the three 11.6 mm T9 screws from the top, back of the printer.
    • Remove the one 12.1 mm T9 screw from the top, back of the printer.
  8. Remove the 11.6mm T9 screw from the top left of the front of the printer. Remove the 11.6mm T9 screw from the top left of the front of the printer.
    • Remove the 11.6mm T9 screw from the top left of the front of the printer.
  9. Disconnect the display by pulling down on the plastic hinge.
    • Disconnect the display by pulling down on the plastic hinge.
    • Gradually apply more force to the hinge and don't worry about the hinge or display breaking.
  10. Lift the display as high as it will allow to expose the back of the display. Remove the connector by pinching the sides and pulling away from the printer. Remove the connector by pulling both away from the display and towards the printer.
    • Lift the display as high as it will allow to expose the back of the display.
    • Remove the connector by pinching the sides and pulling away from the printer.
    • Remove the connector by pulling both away from the display and towards the printer.
  11. Remove the two 11.6 mm T9 screws from beneath the display. Remove the two 11.6 mm T9 screws from beneath the display.
    • Remove the two 11.6 mm T9 screws from beneath the display.
  12. Remove the top of the printer by lifting it from both sides.
    • Remove the top of the printer by lifting it from both sides.
  13. Locate the printhead on the right side of the printer. Pull the white tab on the right side of the printhead up, by pushing on the side of the printer a little bit. Remove the printhead by lifting it out of the housing.
    • Locate the printhead on the right side of the printer.
    • Pull the white tab on the right side of the printhead up, by pushing on the side of the printer a little bit.
    • Remove the printhead by lifting it out of the housing.
Abschluss
Cam Engle
387 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S13-G3, White Fall 2018 Mitglied von Cal Poly, Team S13-G3, White Fall 2018
CPSU-WHITE-F18S13G3
3 Mitglieder
7 Anleitungen geschrieben
This printhead is normally user replaceable.
No screwdrivers are required.
This video is for an 8600, but the process is the same.
https://www.youtube.com/watch?v=i-IluLvF...
Andy - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 5
Letzte 7 Tage: 18
Letzte 30 Tage: 67
Insgesamt: 261
