Einleitung
This guide will help you replace or upgrade your RAM on your HP omen 15 2020 and 2021 models.
Was du brauchst
Make sure the laptop is completely turned off. To properly turn it off, hold the power button for a few seconds until it turns off.
Unplug everything from the computer(USB, HDMI, Charger).
Flip the laptop like in the picture and locate the 8 screws (4 in the front and 4 in the back).
Use a pry tool to remove the cover by going slowly around the laptop.
Put back the bottom panel and make sure to screw the short screws in the front and the long ones in the back.
To make sure everything is working properly follow this video: https://www.youtube.com/watch?v=9SYIvE67...
Eine weitere Person hat diese Anleitung absolviert.
