Zum Hauptinhalt wechseln
HP Omen 15-5002xx Fan Replacement
Was du brauchst
  1. HP Omen 15-5002xx Fan Replacement, Back Cover: Schritt 1, Bild 1 von 2 HP Omen 15-5002xx Fan Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Fan Replacement, Battery: Schritt 2, Bild 1 von 1
    • Open the case slowly from opposite sides of the laptop.
    • Use the J00 JIS screwdriver to remove eight screws securing the battery.
  3. HP Omen 15-5002xx Fan Replacement: Schritt 3, Bild 1 von 2 HP Omen 15-5002xx Fan Replacement: Schritt 3, Bild 2 von 2
    • Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
    • Remove the battery by lifting it up and out.
  4. HP Omen 15-5002xx Fan Replacement, Fan: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Flathead 1.5 mm Screwdriver
    $5.49
    Kaufen
    • Remove the twelve big screws with the J00 JIS screwdriver.
    • Remove all eight small screws with the 1.5 flathead screwdriver.
  5. HP Omen 15-5002xx Fan Replacement: Schritt 5, Bild 1 von 2 HP Omen 15-5002xx Fan Replacement: Schritt 5, Bild 2 von 2
    • Carefully detach the fan connector that is attached to the motherboard by slowly sliding the connector out with two fingers.
    • Remove the battery carefully.
Abschluss
Gateway, Team 1-1, Saknee Fall 2021 Mitglied von Gateway, Team 1-1, Saknee Fall 2021
GCC-SAKNEE-F21S1G1
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 28
Insgesamt: 1,665
