Zum Hauptinhalt wechseln
HP Omen 15-5002xx Motherboard Replacement
Was du brauchst
  1. HP Omen 15-5002xx Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 2 HP Omen 15-5002xx Motherboard Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Motherboard Replacement, Battery: Schritt 2, Bild 1 von 1
    • Open the case slowly from opposite sides of the laptop.
    • Use the J00 JIS screwdriver to remove eight screws securing the battery.
  3. HP Omen 15-5002xx Motherboard Replacement: Schritt 3, Bild 1 von 2 HP Omen 15-5002xx Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
    • Remove the battery by lifting it up and out.
  4. HP Omen 15-5002xx Motherboard Replacement, Fan: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Flathead 1.5 mm Screwdriver
    $5.49
    Kaufen
    • Remove the twelve big screws with the J00 JIS screwdriver.
    • Remove all eight small screws with the 1.5 flathead screwdriver.
  5. HP Omen 15-5002xx Motherboard Replacement: Schritt 5, Bild 1 von 2 HP Omen 15-5002xx Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Carefully detach the fan connector that is attached to the motherboard by slowly sliding the connector out with two fingers.
    • Remove the battery carefully.
  6. HP Omen 15-5002xx Motherboard Replacement, Wi-Fi Card: Schritt 6, Bild 1 von 1
    • Use the Phillips #00 to remove one screw securing the Wi-Fi Card.
  7. HP Omen 15-5002xx Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the Wi-Fi Card by slowly sliding the card sideways away from the motherboard.
  8. HP Omen 15-5002xx Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 1
    $5.49
    Kaufen
    • Use the 1.5 flathead screwdriver and remove the twelve screws from the motherboard.
  9. HP Omen 15-5002xx Motherboard Replacement: Schritt 9, Bild 1 von 3 HP Omen 15-5002xx Motherboard Replacement: Schritt 9, Bild 2 von 3 HP Omen 15-5002xx Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Disconnect the four cables attached to the motherboard.
  10. HP Omen 15-5002xx Motherboard Replacement: Schritt 10, Bild 1 von 2 HP Omen 15-5002xx Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Disconnect the remaining four connectors from the motherboard.
    • Remove the motherboard.
Abschluss
Gateway, Team 1-1, Saknee Fall 2021 Mitglied von Gateway, Team 1-1, Saknee Fall 2021
GCC-SAKNEE-F21S1G1
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 37
Insgesamt: 1,207
