Einleitung
Follow this guide to replace the motherboard of your HP Omen 15-5002xx gaming laptop.
Before beginning this repair, be sure to power off your device and unplug it from external power.
Was du brauchst
Flip the laptop upside down so the backside is facing up.
Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
Unscrew all 14 screw with the J00 JIS Screwdriver.
Open the case slowly from opposite sides of the laptop.
Use the J00 JIS screwdriver to remove eight screws securing the battery.
Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
Remove the battery by lifting it up and out.
Remove the twelve big screws with the J00 JIS screwdriver.
Remove all eight small screws with the 1.5 flathead screwdriver.
Carefully detach the fan connector that is attached to the motherboard by slowly sliding the connector out with two fingers.
Remove the battery carefully.
Carefully remove the Wi-Fi Card by slowly sliding the card sideways away from the motherboard.
Use the 1.5 flathead screwdriver and remove the twelve screws from the motherboard.
Disconnect the remaining four connectors from the motherboard.
Remove the motherboard.
