Zum Hauptinhalt wechseln
HP Omen 15-ax243dx Ventilation Fans Replacement
Was du brauchst
  1. HP Omen 15-ax243dx Ventilation Fans Replacement, Battery: Schritt 1, Bild 1 von 2 HP Omen 15-ax243dx Ventilation Fans Replacement, Battery: Schritt 1, Bild 2 von 2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
    Frag FixBot
    Kommentar hinzufügen
  2. HP Omen 15-ax243dx Ventilation Fans Replacement: Schritt 2, Bild 1 von 2 HP Omen 15-ax243dx Ventilation Fans Replacement: Schritt 2, Bild 2 von 2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
    Frag FixBot
  3. HP Omen 15-ax243dx Ventilation Fans Replacement: Schritt 3, Bild 1 von 2 HP Omen 15-ax243dx Ventilation Fans Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
    Frag FixBot
  4. HP Omen 15-ax243dx Ventilation Fans Replacement: Schritt 4, Bild 1 von 2 HP Omen 15-ax243dx Ventilation Fans Replacement: Schritt 4, Bild 2 von 2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
    Frag FixBot
  5. HP Omen 15-ax243dx Ventilation Fans Replacement, Ventilation Fans: Schritt 5, Bild 1 von 1
    • The two ventilation fans are secured with the system by 5 screws. Unscrew these five 1.2 mm screws using the Phillips #0 screwdriver.
    • When removing the screws, use a magnetic screwdriver to prevent the screws from falling behind the motherboard
    Frag FixBot
  6. HP Omen 15-ax243dx Ventilation Fans Replacement: Schritt 6, Bild 1 von 2 HP Omen 15-ax243dx Ventilation Fans Replacement: Schritt 6, Bild 2 von 2
    • After removing all 5 screws, the fans are still connected with the system through 2 cables.
    • Carefully pull the fan cables out of the connectors on the motherboard.
    • Be cautious when pulling by the wires, this can permanently damage the fans beyond repair.
    Frag FixBot
  7. HP Omen 15-ax243dx Ventilation Fans Replacement: Schritt 7, Bild 1 von 1
    • The fans can now be removed from the device.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 Mitglied von UMass Dartmouth, Team S6-G7, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G7
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 64
Insgesamt: 6,187
