Einleitung
Using a spudger and a 00 Phillips head screwdriver, this guide will show how to remove a battery from an HP Omni 10 tablet in roughly 5 to 10 minutes. Be careful with the battery, as it can be volatile when punctured with metal instruments.
Was du brauchst
Push the black plastic security flaps into an upward position.
Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
Lift the tab on the strip up and pull it across the battery.
Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
Unhook the cord from the edge of the battery.
Pull the wire circuit out and down.
Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
3 weitere Personen haben diese Anleitung absolviert.
