Zum Hauptinhalt wechseln
Einleitung
The scanner tray is the part of the printer that houses the entire scanner. It is connected to the printer by two hinges, 3 white strip wires, and 1 orange brown red and black wire. After the tray is removed the feed rollers can be cleaned, and printer carriage can be replaced.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
    • Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
  2. Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel. Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
    • Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
  3. Press down on the two plastic hinges to remove the upper portion of printer. Press down on the two plastic hinges to remove the upper portion of printer.
    • Press down on the two plastic hinges to remove the upper portion of printer.
  4. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  5. To unplug the speaker wire, grasp the plastic plug on the end of the speaker wire then gently pull the plug away from the printer until removed.
    • To unplug the speaker wire, grasp the plastic plug on the end of the speaker wire then gently pull the plug away from the printer until removed.
  6. Rotate the printer so the paper tray is facing towards you. Gently lift the scanner tray up and away from the printer.
    • Rotate the printer so the paper tray is facing towards you.
    • Gently lift the scanner tray up and away from the printer.
    • Press the gray plastic tabs inward toward to release the tabs from the printer.
  7. Returning to the back of the printer, remove the scanner from the back hinges.
    • Returning to the back of the printer, remove the scanner from the back hinges.
    • With pressure applied, the scanner will detach easily.
  8. Gently grasp and unplug the two white ribbon cables from the printer body.
    • Gently grasp and unplug the two white ribbon cables from the printer body.
    • Be sure to grasp the cable at the connector and not to pull on the wires themselves.
  9. Unplug the white plastic multi-wire connector with the orange, black, red, and brown wires from it's port.
    • Unplug the white plastic multi-wire connector with the orange, black, red, and brown wires from it's port.
    • Be sure to grasp the white connector and not to pull on the wires themselves.
  10. Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
    • Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Angehängte Dateien
Cody Long
144 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 12-31, Maness Spring 2011 Mitglied von Cal Poly, Team 12-31, Maness Spring 2011
CPSU-MANESS-S11S12G31
5 Mitglieder
9 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 5,332
