Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will instruct a user on how to remove the battery in order to replace a potentially faulty piece of hardware. Be sure the device is turned off and disconnected from all power sources.
  1. Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads. Use the Phillips #0 to remove four 9mm screws.
    • Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
    • Use the Phillips #0 to remove four 9mm screws.
    • Use the Phillips #0 to remove seven 6mm screws.
  2. Use the nylon spudger to pry the back casing near the hinges for the screen. Continue to pry along the edge of the back case until the back is ready to be removed. Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. Use the blue plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard. Now carefully pull the cable out of place and remove the entire back casing.
    • Use the blue plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
  4. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  5. Remove the five 6mm screws that hold the battery in place using the Phillips #0.
    • Remove the five 6mm screws that hold the battery in place using the Phillips #0.
  6. Use the nylon spudger to pry away the blue/white wire that is positioned near your battery. Use the nylon spudger to pry away the blue/white wire that is positioned near your battery.
    • Use the nylon spudger to pry away the blue/white wire that is positioned near your battery.
  7. Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab. Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  8. Remove the battery from your device.
    • Remove the battery from your device.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Joseph Lintz
882 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 11-5, Blackwell Fall 2016 Mitglied von USF Tampa, Team 11-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G5
3 Mitglieder
Only four 6mm screws retaining battery, middle screw secures by passing through back cover. Otherwise very helpful.
norman.huntbach - Antwort
i followed every step on this guide and when i was finished my laptop wouldn’t turn on
premium destroyers - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 17
Letzten 30 Tage: 54
Insgesamt: 2,858
