Zum Hauptinhalt wechseln
HP Pavilion 13-s128nr Back Panel Replacement
Was du brauchst
  1. HP Pavilion 13-s128nr Back Panel Replacement, Back Panel: Schritt 1, Bild 1 von 2 HP Pavilion 13-s128nr Back Panel Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Use the iFixit opening tool to take off the rubber caps.
    • Remove the screws using the Phillips #0 screwdriver.
  2. HP Pavilion 13-s128nr Back Panel Replacement: Schritt 2, Bild 1 von 1
    • Use the Jimmy to pry around the seam of the laptop.
    • Remove the back panel of the laptop.
    • Don't completely remove the back panel as there are ribbon cables that can be easily damaged if removed quickly.
  3. HP Pavilion 13-s128nr Back Panel Replacement: Schritt 3, Bild 1 von 2 HP Pavilion 13-s128nr Back Panel Replacement: Schritt 3, Bild 2 von 2
    • Using the iFixit opening tool to lift the tabs holding in the cables connecting the keyboard to the motherboard.
    • Pull the cable from the motherboard.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 23
Insgesamt: 1,192
