Zum Hauptinhalt wechseln
HP Pavilion 14-b015dx Cooling Fan Replacement
Was du brauchst
  1. HP Pavilion 14-b015dx Cooling Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the computer is completely powered down and unplug the power cord.
  2. HP Pavilion 14-b015dx Cooling Fan Replacement: Schritt 2, Bild 1 von 1
    • Place the device on your work surface with bottom facing up and the battery located at the top.
  3. HP Pavilion 14-b015dx Cooling Fan Replacement: Schritt 3, Bild 1 von 1
    • Slide the left release tab toward the center of the computer to the unlock position. Next slid the right tab toward the center of the computer and hold it there while completing step 4.
  4. HP Pavilion 14-b015dx Cooling Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery by sliding it upwards and away from the computer.
  5. HP Pavilion 14-b015dx Cooling Fan Replacement, Keyboard: Schritt 5, Bild 1 von 1
    • Unscrew the ten 6.0 mm Philips head screws on the base of the device with a Phillips #0 head screwdriver.
  6. HP Pavilion 14-b015dx Cooling Fan Replacement: Schritt 6, Bild 1 von 1
    • Insert the plastic opening tool between the keyboard and the plastic housing.
    • Pry the keyboard upward away from the device.
    • Move the tool around the edge of the entire keyboard while continuing to pry.
    • You will hear the clips pop once you have released them.
  7. HP Pavilion 14-b015dx Cooling Fan Replacement: Schritt 7, Bild 1 von 1
    • Once you have released all of the clips, slowly lift the keyboard exposing the ribbon cable.
    • Lift the tab on the keyboard ZIF connector with a plastic opening tool and gently remove the ribbon cable.
  8. HP Pavilion 14-b015dx Cooling Fan Replacement, Palm Rest: Schritt 8, Bild 1 von 1
    • Remove the eight 6.0 mm screws located under the keyboard with your Philips #0 screwdriver.
  9. HP Pavilion 14-b015dx Cooling Fan Replacement: Schritt 9, Bild 1 von 1
    • Remove the track pad and power button ribbon cables.
    • Lift the locking bar on each connector with a plastic opening tool and gently remove the ribbon cables
  10. HP Pavilion 14-b015dx Cooling Fan Replacement: Schritt 10, Bild 1 von 1
    • To remove the palm rest, insert the plastic opening tool in the seam between the palm rest and the base.
    • Pry upward to undo each clip.
    • Continue this process around the entire palm rest.
  11. HP Pavilion 14-b015dx Cooling Fan Replacement: Schritt 11, Bild 1 von 1
    • Once all clips have been undone lift the palm rest away from the laptop.
  12. HP Pavilion 14-b015dx Cooling Fan Replacement, Cooling Fan: Schritt 12, Bild 1 von 1
    • Your now ready to remove the cooling fan.
    • Disconnect the cable that connects the fan to the motherboard.
  13. HP Pavilion 14-b015dx Cooling Fan Replacement: Schritt 13, Bild 1 von 1
    • Unscrew the three 6.0 mm screws on each corner securing the cooling fan with a Phillips #0 screwdriver.
  14. HP Pavilion 14-b015dx Cooling Fan Replacement: Schritt 14, Bild 1 von 1
    • Remove the cooling fan by lifting upwards and pulling to the right.
Abschluss
Gregory Bridge
623 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 Mitglied von UMass Dartmouth, Team S1-G1, Isaacson Fall 2017
UMASSD-ISAACSON-F17S1G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 554
