Zum Hauptinhalt wechseln
HP Pavilion 14-b120dx Wireless Card Replacement
Was du brauchst
  1. HP Pavilion 14-b120dx Wireless Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. HP Pavilion 14-b120dx Wireless Card Replacement: Schritt 2, Bild 1 von 3 HP Pavilion 14-b120dx Wireless Card Replacement: Schritt 2, Bild 2 von 3 HP Pavilion 14-b120dx Wireless Card Replacement: Schritt 2, Bild 3 von 3
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
  3. HP Pavilion 14-b120dx Wireless Card Replacement, Keyboard: Schritt 3, Bild 1 von 3 HP Pavilion 14-b120dx Wireless Card Replacement, Keyboard: Schritt 3, Bild 2 von 3 HP Pavilion 14-b120dx Wireless Card Replacement, Keyboard: Schritt 3, Bild 3 von 3
    • Insert the plastic opening tool between the keyboard and the palm rest.
    • Pry upwards until the keyboard section detaches from the laptop.
    • Repeat this around the edge of the entire keyboard.
    • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
  4. HP Pavilion 14-b120dx Wireless Card Replacement: Schritt 4, Bild 1 von 2 HP Pavilion 14-b120dx Wireless Card Replacement: Schritt 4, Bild 2 von 2
    • Lift the keyboard slowly up until the connecting cable is exposed.
    • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Detach the cable.
  5. HP Pavilion 14-b120dx Wireless Card Replacement, Palm Rest: Schritt 5, Bild 1 von 2 HP Pavilion 14-b120dx Wireless Card Replacement, Palm Rest: Schritt 5, Bild 2 von 2
    • Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
  6. HP Pavilion 14-b120dx Wireless Card Replacement: Schritt 6, Bild 1 von 3 HP Pavilion 14-b120dx Wireless Card Replacement: Schritt 6, Bild 2 von 3 HP Pavilion 14-b120dx Wireless Card Replacement: Schritt 6, Bild 3 von 3
    • Insert the plastic opening tool into the seam between the palm rest and the laptop.
    • Pry upwards until the palm rest separates from the laptop.
    • Repeat this process around the entire computer.
    • These steps will be similar to the ones you took to remove the keyboard. Again, you will hear snapping noises.
  7. HP Pavilion 14-b120dx Wireless Card Replacement: Schritt 7, Bild 1 von 1
    • Lift upwards to remove the palm rest.
  8. HP Pavilion 14-b120dx Wireless Card Replacement, Wireless Card: Schritt 8, Bild 1 von 2 HP Pavilion 14-b120dx Wireless Card Replacement, Wireless Card: Schritt 8, Bild 2 von 2
    • Remove the two 4.0 mm screws using a Philips #00 head screwdriver.
  9. HP Pavilion 14-b120dx Wireless Card Replacement: Schritt 9, Bild 1 von 2 HP Pavilion 14-b120dx Wireless Card Replacement: Schritt 9, Bild 2 von 2
    • Detach the two wires connecting to the motherboard to the wireless card.
  10. HP Pavilion 14-b120dx Wireless Card Replacement: Schritt 10, Bild 1 von 2 HP Pavilion 14-b120dx Wireless Card Replacement: Schritt 10, Bild 2 von 2
    • Slide the card upwards and outwards to detach it from the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Erin Lavalla
458 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 4-4, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 4-4, Catania Fall 2016
UMASSD-CATANIA-F16S4G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 527
