Einleitung
Using this guide will help you in replacing the screen in your HP Pavilion 14-bk061st.
The screen is an important part of all laptops. Some may consider replacing the screen once issues arise during use such as cracked screens after a fall or vertical or horizontal lines sometimes caused by a loose or frayed video cable.
Was du brauchst
Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
Remove the five JIS #1 screws that attach the hinges of the screen to the casing of the laptop.
Carefully lift the hinges from the encasing and lift the bottom half of the laptop away from the screen.
Use the metal spudger to carefully pry off the plastic encasing around the monitor.
Carefully remove the sticker covering the wire that connects the screen to the motherboard.
Disconnect the cable that is connected to the screen.
Eine weitere Person hat diese Anleitung absolviert.
