Zum Hauptinhalt wechseln
HP Pavilion 14-c015dx Chromebook Keyboard Replacement
Was du brauchst
  1. HP Pavilion 14-c015dx Chromebook Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Remove the two 7mm screws with a Phillips Head #1 Screwdriver.
    • These screws may not completely come out of the laptop, so just make sure that you have loosened them all of the way.
  2. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Starting from the left side, use the metal spudger to pry off the keyboard.
    • Run the spudger across the edges until all plastic clips are popped up and the keyboard is free from the palm rest assembly.
    • Do not pull the keyboard away from the computer while popping the keyboard off, there is a connector cable in the bottom center of the keyboard that will be disconnected in the next step.
  3. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: Schritt 3, Bild 1 von 3 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: Schritt 3, Bild 2 von 3 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Detach the circuit connector by flipping up the black flap upwards and gently pulling the connector out by pulling up on the blue release tab.
    • Lift the keyboard away from the computer once the connector is detached.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Joe Kennedy
231 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 22-8, Maness Winter 2017 Mitglied von Cal Poly, Team 22-8, Maness Winter 2017
CPSU-MANESS-W17S22G8
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 454
