Zum Hauptinhalt wechseln
HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement
Was du brauchst
  1. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Remove the two 7mm screws with a Phillips Head #1 Screwdriver.
    • These screws may not completely come out of the laptop, so just make sure that you have loosened them all of the way.
  2. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Starting from the left side, use the metal spudger to pry off the keyboard.
    • Run the spudger across the edges until all plastic clips are popped up and the keyboard is free from the palm rest assembly.
    • Do not pull the keyboard away from the computer while popping the keyboard off, there is a connector cable in the bottom center of the keyboard that will be disconnected in the next step.
  3. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 3, Bild 1 von 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 3, Bild 2 von 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Detach the circuit connector by flipping up the black flap upwards and gently pulling the connector out by pulling up on the blue release tab.
    • Lift the keyboard away from the computer once the connector is detached.
  4. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement, Solid State Hard Drive: Schritt 4, Bild 1 von 2 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement, Solid State Hard Drive: Schritt 4, Bild 2 von 2
    • Locate these seven 5mm circled screws on the panel that was under the keyboard.
    • Remove the screws with a Phillips Head #1 Screwdriver.
  5. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 5, Bild 1 von 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 5, Bild 2 von 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Locate the ribbon cable near the top of the keyboard area.
    • At the cable base, lift the white tab with a fingernail and then gently pull on the blue tab of the cable to release it.
  6. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 6, Bild 1 von 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 6, Bild 2 von 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Locate the ribbon cable just above the touchpad.
    • Disconnect the cable by lifting the white tab at the base of the cable with a fingernail and then pulling on the blue section of the cable.
  7. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 7, Bild 1 von 2 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Locate these eight 7mm screws on the bottom of the laptop.
    • Remove using a Philips Head #1 screwdriver.
  8. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Flip the computer back over, and using the metal spudger, remove the plastic palm rest assembly.
    • Go little by little around the edge and carefully pry off the plastic palm rest assembly.
  9. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 9, Bild 1 von 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 9, Bild 2 von 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 9, Bild 3 von 3
    • Locate the plastic flap holding the metal strip in place.
    • Disconnect the cable by lifting the white tab at the base of the cable with a fingernail and then gently pulling on the blue section of the cable.
  10. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 10, Bild 1 von 2 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 10, Bild 2 von 2
    • Locate these 3 screws and unscrew using a Philips Head #1 screwdriver.
  11. HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 11, Bild 1 von 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 11, Bild 2 von 3 HP Pavilion 14-c015dx Chromebook Solid State Hard Drive Replacement: Schritt 11, Bild 3 von 3
    • Lift up the hard drive slightly and remove the black cable strip connecting the hard drive to the computer
    • Do not lift the hard drive very high, the connector cable is not very long and may get damaged if you pull too far
    • You may need to use some force and wiggling to release it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
William Busby
234 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 22-8, Maness Winter 2017 Mitglied von Cal Poly, Team 22-8, Maness Winter 2017
CPSU-MANESS-W17S22G8
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 16
Insgesamt: 789
