Einleitung
This guide will show you the steps to replace the Solid State Hard Drive.
Was du brauchst
Starting from the left side, use the metal spudger to pry off the keyboard.
Run the spudger across the edges until all plastic clips are popped up and the keyboard is free from the palm rest assembly.
Detach the circuit connector by flipping up the black flap upwards and gently pulling the connector out by pulling up on the blue release tab.
Lift the keyboard away from the computer once the connector is detached.
Locate these seven 5mm circled screws on the panel that was under the keyboard.
Remove the screws with a Phillips Head #1 Screwdriver.
Locate the ribbon cable near the top of the keyboard area.
At the cable base, lift the white tab with a fingernail and then gently pull on the blue tab of the cable to release it.
Locate the ribbon cable just above the touchpad.
Disconnect the cable by lifting the white tab at the base of the cable with a fingernail and then pulling on the blue section of the cable.
Locate these eight 7mm screws on the bottom of the laptop.
Remove using a Philips Head #1 screwdriver.
Flip the computer back over, and using the metal spudger, remove the plastic palm rest assembly.
Go little by little around the edge and carefully pry off the plastic palm rest assembly.
Locate the plastic flap holding the metal strip in place.
Disconnect the cable by lifting the white tab at the base of the cable with a fingernail and then gently pulling on the blue section of the cable.
Lift up the hard drive slightly and remove the black cable strip connecting the hard drive to the computer
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
