Zum Hauptinhalt wechseln
HP Pavilion 14-cf0014dx RAM Replacement
Was du brauchst
  1. HP Pavilion 14-cf0014dx RAM Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx RAM Replacement: Schritt 2, Bild 1 von 1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx RAM Replacement, Battery: Schritt 3, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx RAM Replacement: Schritt 4, Bild 1 von 1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx RAM Replacement, RAM: Schritt 5, Bild 1 von 3 HP Pavilion 14-cf0014dx RAM Replacement, RAM: Schritt 5, Bild 2 von 3 HP Pavilion 14-cf0014dx RAM Replacement, RAM: Schritt 5, Bild 3 von 3
    • Using your fingers, simultaneously press the two silver clamps away from each other to release the RAM.
    • Each RAM stick will pop up at a 45 degree angle.
    • Remove the RAM from the device.
Abschluss
Sam Cole
813 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 2-7, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G7
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 382
