Zum Hauptinhalt wechseln
HP Pavilion 14-cf0014dx WLAN Card Replacement
Was du brauchst
  1. HP Pavilion 14-cf0014dx WLAN Card Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx WLAN Card Replacement: Schritt 2, Bild 1 von 1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx WLAN Card Replacement, Battery: Schritt 3, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx WLAN Card Replacement: Schritt 4, Bild 1 von 1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx WLAN Card Replacement, WLAN Card: Schritt 5, Bild 1 von 2 HP Pavilion 14-cf0014dx WLAN Card Replacement, WLAN Card: Schritt 5, Bild 2 von 2
    • Disconnect the cable from the WLAN card.
  6. HP Pavilion 14-cf0014dx WLAN Card Replacement: Schritt 6, Bild 1 von 2 HP Pavilion 14-cf0014dx WLAN Card Replacement: Schritt 6, Bild 2 von 2
    • Using the Phillips #0 screwdriver, remove the single screw securing the WLAN card to the motherboard.
  7. HP Pavilion 14-cf0014dx WLAN Card Replacement: Schritt 7, Bild 1 von 2 HP Pavilion 14-cf0014dx WLAN Card Replacement: Schritt 7, Bild 2 von 2
    • Carefully lift and remove the WLAN card from the device.
Abschluss
Sam Cole
813 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 2-7, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G7
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 192
