Einleitung
Over time, Chromebook batteries may die, leaving it unable to charge. Speakers are sensitive and can get blown out after long use on full volume. This guide will show you how to remove the internal parts: the battery and the speakers, with prerequisite guide for removing keyboard panel.
Was du brauchst
Turn the laptop over.
Remove all nine 3mm screws on back panel with a Phillips Head 1 driver.
Flip the laptop right side up and open the clamshell.
Starting at the bottom right corner, slide the opening tool into the crevice between the blue and silver panels.
Carefully pry the top casing up around the edges, moving counterclockwise.
Close the laptop and orient it on its side (clamshell hinge up), carefully holding it steady to ensure its safety.
Insert the opening tool inside of the hinge and pry with an even amount of force to disconnect the keyboard panel from the fan grate.
Reorient the laptop in an upright fashion and open the clamshell.
If needed, continue to pry the silver keyboard panel from the rest of the hardware with minimal force.
Slowly slide the silver keyboard panel towards you while lifting gently to separate the halves.
While keeping silver keyboard panel hovering above the laptop, locate the touchpad connector ribbon attached to both the silver panel and motherboard.
With your finger, flip up the white clasp that holds the connector, releasing the connector ribbon.
Unpeel the connector ribbon from its position on the motherboard.
With your finger, flip up the white clasp that connects the larger keyboard connector to the motherboard, releasing the connector ribbon.
Gently pull the connector ribbon from the clasp.
Lift the keyboard panel up and away from the CPU, completely revealing the mainframe.
With the internal hardware exposed, disconnect the battery cable from the motherboard.
If tightly fastened, gently wiggle the plug out of the jack.
Remove the three 4mm screws around the perimeter of the battery pack with a Phillips Head 1 screwdriver.
Flip up the two white clasps that hold the connector ribbon to the battery to release the ribbon.
Remove the 'motherboard to USB board' connector ribbon from its place.
Detach the speaker cable from its fastener on the motherboard by pulling it out with your fingers or using a spudger.
Using your fingers, gently pry out the two L-shaped speaker panels from between the external casing and battery pack.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Thank you for your instructions!!! HP and Chromebook sites had nothing!!! Sure they had instructions but nothing regarding how to remove the battery. The only instruction read- -remove battery!!!! Drrrrrr
