Zum Hauptinhalt wechseln
HP Pavilion 15-AB153NR Speaker Replacement
Was du brauchst
  1. HP Pavilion 15-AB153NR Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure computer is turned off and unplugged.
    • Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
  2. HP Pavilion 15-AB153NR Speaker Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-AB153NR Speaker Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery release latch on the right with continuous force from right to left.
    • Once battery pops, you may release latch.
  3. HP Pavilion 15-AB153NR Speaker Replacement: Schritt 3, Bild 1 von 2 HP Pavilion 15-AB153NR Speaker Replacement: Schritt 3, Bild 2 von 2
    • Grab the battery, rotating upwards and away from you. This will remove the battery.
  4. HP Pavilion 15-AB153NR Speaker Replacement, CD/DVD Drive: Schritt 4, Bild 1 von 1
    • Make sure computer is powered off and unplugged.
    • Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
  5. HP Pavilion 15-AB153NR Speaker Replacement: Schritt 5, Bild 1 von 1
    • Using the Phillips #000 screwdriver, remove the 7 mm screw on the middle right.
    • There is an icon that looks like a CD stamped into the back panel near this screw.
  6. HP Pavilion 15-AB153NR Speaker Replacement: Schritt 6, Bild 1 von 2 HP Pavilion 15-AB153NR Speaker Replacement: Schritt 6, Bild 2 von 2
    • Slide the drive out from the right side of the device.
  7. HP Pavilion 15-AB153NR Speaker Replacement, Bottom Case Cover: Schritt 7, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove the two 12mm screws located on the hinge covers.
  8. HP Pavilion 15-AB153NR Speaker Replacement: Schritt 8, Bild 1 von 2 HP Pavilion 15-AB153NR Speaker Replacement: Schritt 8, Bild 2 von 2
    • Lift the corner covers off of the computer using a prying tool.
  9. HP Pavilion 15-AB153NR Speaker Replacement: Schritt 9, Bild 1 von 1
    • Remove the six 6.5mm screws using a Phillips #1 screwdriver that are located near the top of the laptop.
  10. HP Pavilion 15-AB153NR Speaker Replacement: Schritt 10, Bild 1 von 1
    • Remove the remaining seven 6.5mm screws using a Phillips #1 screwdriver that are securing the back cover.
  11. HP Pavilion 15-AB153NR Speaker Replacement: Schritt 11, Bild 1 von 1
    • Use the Phillips #0 screwdriver to remove the two 2mm screws.
  12. HP Pavilion 15-AB153NR Speaker Replacement: Schritt 12, Bild 1 von 3 HP Pavilion 15-AB153NR Speaker Replacement: Schritt 12, Bild 2 von 3 HP Pavilion 15-AB153NR Speaker Replacement: Schritt 12, Bild 3 von 3
    • Use prying tools to pry the covers off of the screwholes.
    • Using the Phillips #1 screwdriver, remove the two 6.5mm screws.
  13. HP Pavilion 15-AB153NR Speaker Replacement: Schritt 13, Bild 1 von 1
    • Be mindful of sharp edges on computer while using prying tools.
    • Flip computer over and open so that the screen is facing you.
    • Starting at the bottom right corner, insert the prying tool and lift upwards to loosen the back panel.
    • Continue down all sides and corners of the device.
  14. HP Pavilion 15-AB153NR Speaker Replacement: Schritt 14, Bild 1 von 2 HP Pavilion 15-AB153NR Speaker Replacement: Schritt 14, Bild 2 von 2
    • Flip laptop back over so that the bottom is facing up
    • After all sides are loosened, remove the back panel from the device.
  15. HP Pavilion 15-AB153NR Speaker Replacement, Cooling Fan: Schritt 15, Bild 1 von 2 HP Pavilion 15-AB153NR Speaker Replacement, Cooling Fan: Schritt 15, Bild 2 von 2
    • Disconnect fan cable from the motherboard.
  16. HP Pavilion 15-AB153NR Speaker Replacement: Schritt 16, Bild 1 von 1
    • Remove both 3mm screws connected to the fan using Phillips #1 screwdriver.
  17. HP Pavilion 15-AB153NR Speaker Replacement: Schritt 17, Bild 1 von 2 HP Pavilion 15-AB153NR Speaker Replacement: Schritt 17, Bild 2 von 2
    • Remove the fan from the computer.
  18. HP Pavilion 15-AB153NR Speaker Replacement, Speaker: Schritt 18, Bild 1 von 2 HP Pavilion 15-AB153NR Speaker Replacement, Speaker: Schritt 18, Bild 2 von 2
    • Disconnect wiring harnesses by gently applying pressure to the plastic clip. Do not pull on the wires.
    • Disconnect the wiring harness that is routed through the speaker from the motherboard.
    • Remove the wiring harness from the groove in the speaker.
  19. HP Pavilion 15-AB153NR Speaker Replacement: Schritt 19, Bild 1 von 2 HP Pavilion 15-AB153NR Speaker Replacement: Schritt 19, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Disconnect the speaker wiring from the motherboard.
    • If this clip is too difficult to remove by hand, tweezers or pliers can be used to gently initiate separation.
  20. HP Pavilion 15-AB153NR Speaker Replacement: Schritt 20, Bild 1 von 2 HP Pavilion 15-AB153NR Speaker Replacement: Schritt 20, Bild 2 von 2
    • Remove the speakers.
Abschluss
Matt Houppert
97 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G1, Stella Fall 2019 Mitglied von IUPUI, Team S2-G1, Stella Fall 2019
IUPUI-STELLA-F19S2G1
4 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 565
