Einleitung
This replacement will require the use of prying tools and screwdrivers. It can completed with moderate difficulty. Make sure you have a moderate chunk of time to complete this task. You will need a clear work surface. Replacing the WiFi card can often solve problems such as connecting to wireless complications.
Was du brauchst
Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
Slide the battery release latch on the right with continuous force from right to left.
Once battery pops, you may release latch.
Grab the battery, rotating upwards and away from you. This will remove the battery.
Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
Using the Phillips #000 screwdriver, remove the 7 mm screw on the middle right.
Using the Phillips #1 screwdriver, remove the two 12mm screws located on the hinge covers.
Remove the six 6.5mm screws using a Phillips #1 screwdriver that are located near the top of the laptop.
Remove the remaining seven 6.5mm screws using a Phillips #1 screwdriver that are securing the back cover.
Use prying tools to pry the covers off of the screwholes.
Using the Phillips #1 screwdriver, remove the two 6.5mm screws.
Flip computer over and open so that the screen is facing you.
Starting at the bottom right corner, insert the prying tool and lift upwards to loosen the back panel.
Continue down all sides and corners of the device.
Flip laptop back over so that the bottom is facing up
After all sides are loosened, remove the back panel from the device.
Using Phillips #0 screwdriver, remove the 3mm screw that connects the card to the motherboard.
Use sliding motion to disconnect other side.
