Einleitung
This guide highlights the removal/replacement of the battery for the HP Pavilion 15-ab165us. The battery is a part used in electronics to power the entire device. When the battery becomes damaged or begins to not perform as it used to, it is recommended to replace the battery. CAUTION: If the battery is swollen or damaged be careful removing the part, and dispose of it properly.
Was du brauchst
Using your other hand, move the tab on the right to the unlocked position and hold.
Keep your hand in the unlocked position, and maneuver the plastic opening tool in the battery crack and pry upwards.
