Zum Hauptinhalt wechseln
HP Pavilion 15-ab165us Hard Drive Replacement
Was du brauchst
  1. HP Pavilion 15-ab165us Hard Drive Replacement, Battery and Back Cover: Schritt 1, Bild 1 von 2 HP Pavilion 15-ab165us Hard Drive Replacement, Battery and Back Cover: Schritt 1, Bild 2 von 2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Hard Drive Replacement: Schritt 2, Bild 1 von 3 HP Pavilion 15-ab165us Hard Drive Replacement: Schritt 2, Bild 2 von 3 HP Pavilion 15-ab165us Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Hard Drive Replacement: Schritt 3, Bild 1 von 3 HP Pavilion 15-ab165us Hard Drive Replacement: Schritt 3, Bild 2 von 3 HP Pavilion 15-ab165us Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Hard Drive Replacement: Schritt 7, Bild 1 von 2 HP Pavilion 15-ab165us Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Hard Drive Replacement, Hard Drive: Schritt 9, Bild 1 von 1
    • Locate the ribbon cable connecting the hard drive to the motherboard.
  10. HP Pavilion 15-ab165us Hard Drive Replacement: Schritt 10, Bild 1 von 1
    • On the motherboard, lift the white tab up to release the ribbon cable.
  11. HP Pavilion 15-ab165us Hard Drive Replacement: Schritt 11, Bild 1 von 1
    • Pull the blue tab up and out from the motherboard to disconnect the ribbon cable.
  12. HP Pavilion 15-ab165us Hard Drive Replacement: Schritt 12, Bild 1 von 1
    • Pull the hard drive out of the enclosure.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
UW Tacoma, Team S1-G2, Rose Fall 2017 Mitglied von UW Tacoma, Team S1-G2, Rose Fall 2017
UWT-ROSE-F17S1G2
5 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 34
Insgesamt: 2,228
