Zum Hauptinhalt wechseln
HP Pavilion 15-ab165us Motherboard Replacement
Was du brauchst
  1. HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: Schritt 1, Bild 1 von 2 HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: Schritt 1, Bild 2 von 2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 2, Bild 1 von 3 HP Pavilion 15-ab165us Motherboard Replacement: Schritt 2, Bild 2 von 3 HP Pavilion 15-ab165us Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 3, Bild 1 von 3 HP Pavilion 15-ab165us Motherboard Replacement: Schritt 3, Bild 2 von 3 HP Pavilion 15-ab165us Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 7, Bild 1 von 2 HP Pavilion 15-ab165us Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Motherboard Replacement, Motherboard: Schritt 9, Bild 1 von 1
    • Locate the motherboard.
  10. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 10, Bild 1 von 2 HP Pavilion 15-ab165us Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Disconnect the wire connected to the Wifi card.
  11. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Disconnect the speakers.
  12. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 12, Bild 1 von 3 HP Pavilion 15-ab165us Motherboard Replacement: Schritt 12, Bild 2 von 3 HP Pavilion 15-ab165us Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Unlock and disconnect cables attached to the motherboard that connect to the display.
  13. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 13, Bild 1 von 2 HP Pavilion 15-ab165us Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Unlock and remove the cable connected to the optical drive.
  14. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 14, Bild 1 von 2 HP Pavilion 15-ab165us Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Unlock and remove the cable that connects to the hard drive.
  15. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 15, Bild 1 von 3 HP Pavilion 15-ab165us Motherboard Replacement: Schritt 15, Bild 2 von 3 HP Pavilion 15-ab165us Motherboard Replacement: Schritt 15, Bild 3 von 3
    • Unlock and remove the cables connected to the keyboard.
  16. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 16, Bild 1 von 1
    • Remove the 4mm screws holding the motherboard in place with a Phillips #1 screwdriver.
  17. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 17, Bild 1 von 1
  18. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 18, Bild 1 von 2 HP Pavilion 15-ab165us Motherboard Replacement: Schritt 18, Bild 2 von 2
    • Disconnect the fan pins.
    • Lift up to remove the fan.
  19. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 19, Bild 1 von 1
    • Release motherboard from the clip at the base of the hard drive.
  20. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 20, Bild 1 von 2 HP Pavilion 15-ab165us Motherboard Replacement: Schritt 20, Bild 2 von 2
    • Lift the motherboard up and flip it around to reveal the cable connected on the underside.
  21. HP Pavilion 15-ab165us Motherboard Replacement: Schritt 21, Bild 1 von 2 HP Pavilion 15-ab165us Motherboard Replacement: Schritt 21, Bild 2 von 2
    • Unlock and disconnect the cable connected to the underside of the motherboard.
    • Pull the motherboard out of the chassis.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Dillon Hubble
653 Reputation
3 Anleitungen geschrieben
UW Tacoma, Team S1-G2, Rose Fall 2017 Mitglied von UW Tacoma, Team S1-G2, Rose Fall 2017
UWT-ROSE-F17S1G2
5 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 1,494
