Einleitung
This guide will teach you how to safely remove a defective or damaged Wi-Fi card in the HP Pavilion 15-ab165us laptop.
Was du brauchst
Flip the computer over so that the bottom cover is facing you.
Slide the two locks to the "unlock" position and remove the battery.
Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
Use a plastic opening tool to remove the plastic feet.
Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
Flip the computer back over.
Use a plastic opening tool to release the clips holding the keyboard section in place.
Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
Pull the cable from the clips and use the spudger to disconnect the wire from the Wi-Fi card.
