Zum Hauptinhalt wechseln
HP Pavilion 15-au123cl CD Drive Replacement
Was du brauchst
  1. HP Pavilion 15-au123cl CD Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl CD Drive Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-au123cl CD Drive Replacement: Schritt 2, Bild 2 von 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl CD Drive Replacement: Schritt 3, Bild 1 von 2 HP Pavilion 15-au123cl CD Drive Replacement: Schritt 3, Bild 2 von 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl CD Drive Replacement: Schritt 4, Bild 1 von 2 HP Pavilion 15-au123cl CD Drive Replacement: Schritt 4, Bild 2 von 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl CD Drive Replacement: Schritt 5, Bild 1 von 3 HP Pavilion 15-au123cl CD Drive Replacement: Schritt 5, Bild 2 von 3 HP Pavilion 15-au123cl CD Drive Replacement: Schritt 5, Bild 3 von 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl CD Drive Replacement, CD Drive: Schritt 6, Bild 1 von 1
    • The CD Drive is located at the bottom right area of the motherboard.
  7. HP Pavilion 15-au123cl CD Drive Replacement: Schritt 7, Bild 1 von 2 HP Pavilion 15-au123cl CD Drive Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the CD drive from the motherboard connector on the left.
Abschluss
USF Tampa, Team S13-G3, Cagle Fall 2017 Mitglied von USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 560
