Zum Hauptinhalt wechseln
HP Pavilion 15-au123cl Fan Replacement
Was du brauchst
  1. HP Pavilion 15-au123cl Fan Replacement, Fan: Schritt 1, Bild 1 von 2 HP Pavilion 15-au123cl Fan Replacement, Fan: Schritt 1, Bild 2 von 2
    • Remove the ten screws from the back case with a Phillips #0 screwdriver.
    • Using a plastic opening tool, pry the CD drive from the computer.
    • Remove the back panel from the computer.
  2. HP Pavilion 15-au123cl Fan Replacement: Schritt 2, Bild 1 von 1
    • Wearing an anti-static bracelet, disconnect the battery cable from the top of the battery with a spudger or plastic opening tool.
    • Remove the three screws from the fan assembly using a Phillips #0 screwdriver.
    • Gently disconnect the fan cable cable.
    • Remove the fan.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 548
