Was du brauchst
Remove the ten screws from the back case with a Phillips #0 screwdriver.
Using a plastic opening tool, pry the CD drive from the computer.
Remove the back panel from the computer.
Wearing an anti-static bracelet, disconnect the battery cable from the top of the battery with a spudger or plastic opening tool.
Remove the three screws from the fan assembly using a Phillips #0 screwdriver.
Gently disconnect the fan cable cable.
Remove the fan.
