Einleitung
By following this guide, you will be able to change the RAM sticks on your laptop. You may wish to do this if you want to upgrade the maximum RAM available or if you are noticing slowdown on your computer. You will first remove the battery before you remove the RAM.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Make sure the laptop is off and unplugged before starting.
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel. Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. Using the plastic opening tool, remove the back cover of the laptop. It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place. Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  6. Carefully disconnect the cable connecting the top of the battery and remove the battery. Carefully disconnect the cable connecting the top of the battery and remove the battery. Carefully disconnect the cable connecting the top of the battery and remove the battery.
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  7. The RAM is located at the lower middle region of the motherboard. Push down on the clips on both sides of the RAM stick evenly.
    • The RAM is located at the lower middle region of the motherboard.
    • Push down on the clips on both sides of the RAM stick evenly.
    • The RAM will become loose and move upward when the clips are pushed.
  8. Pull the RAM stick out of the motherboard.
    • Pull the RAM stick out of the motherboard.
    • The same steps work on both sticks of RAM.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Mohammad Gardezi
886 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S13-G3, Cagle Fall 2017 Mitglied von USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Mitglieder
Thanks mate….your steps are helpful <3
Can you please guide on how to buy the RAM for this laptop…my current RAM is 4GB
Im planning to upgrade to 8GB
thanks
Gokul Prasad Rao - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 25
Insgesamt: 384
