Einleitung
This replacement guide will show how to replace the fan inside of a HP Pavilion 15-b109wm. This process will take between 30-45 minutes, if done correctly. Remember to take your time and do the steps correctly since you are working near the motherboard.
Was du brauchst
Push both buttons towards one another simultaneously. The battery slightly pops out.
Turn the device onto its side.
Using a heavy duty spudger, gently disengage the keyboard.
Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
Using a JIS #1 screwdriver, remove the five 5mm screws.
Detach the power button cable.
Detach the touch pad cable.
Using a plastic opening tool, pry open the top cover.
Unscrew the two 5 mm screws using a JIS #1 screwdriver.
Gently, pull to detach the fan cable.
