Zum Hauptinhalt wechseln
HP Pavilion 15-b109wm Fan Replacement
Was du brauchst
  1. HP Pavilion 15-b109wm Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off the device and disconnect from any power source.
  2. HP Pavilion 15-b109wm Fan Replacement: Schritt 2, Bild 1 von 1
    • Turn the device upside down and ensure the back of the device is facing you.
  3. HP Pavilion 15-b109wm Fan Replacement: Schritt 3, Bild 1 von 3 HP Pavilion 15-b109wm Fan Replacement: Schritt 3, Bild 2 von 3 HP Pavilion 15-b109wm Fan Replacement: Schritt 3, Bild 3 von 3
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. HP Pavilion 15-b109wm Fan Replacement: Schritt 4, Bild 1 von 3 HP Pavilion 15-b109wm Fan Replacement: Schritt 4, Bild 2 von 3 HP Pavilion 15-b109wm Fan Replacement: Schritt 4, Bild 3 von 3
    • Pull out the battery from the device's battery slot.
  5. HP Pavilion 15-b109wm Fan Replacement, Keyboard: Schritt 5, Bild 1 von 2 HP Pavilion 15-b109wm Fan Replacement, Keyboard: Schritt 5, Bild 2 von 2
    • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
  6. HP Pavilion 15-b109wm Fan Replacement: Schritt 6, Bild 1 von 1
    • Locate the two screw holes that allow access to removing the keyboard.
    • There is a keyboard sign beside both keyboard access holes.
  7. HP Pavilion 15-b109wm Fan Replacement: Schritt 7, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Heavy-Duty Spudger
    • Turn the device onto its side.
    • Using a heavy duty spudger, gently disengage the keyboard.
  8. HP Pavilion 15-b109wm Fan Replacement: Schritt 8, Bild 1 von 2 HP Pavilion 15-b109wm Fan Replacement: Schritt 8, Bild 2 von 2
    • Using a plastic opening tool, release the keyboard clips.
  9. HP Pavilion 15-b109wm Fan Replacement: Schritt 9, Bild 1 von 1
    • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
  10. HP Pavilion 15-b109wm Fan Replacement: Schritt 10, Bild 1 von 3 HP Pavilion 15-b109wm Fan Replacement: Schritt 10, Bild 2 von 3 HP Pavilion 15-b109wm Fan Replacement: Schritt 10, Bild 3 von 3
    • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
    • To detach the connector, release by lifting the black plastic tab up.
  11. HP Pavilion 15-b109wm Fan Replacement, Fan: Schritt 11, Bild 1 von 3 HP Pavilion 15-b109wm Fan Replacement, Fan: Schritt 11, Bild 2 von 3 HP Pavilion 15-b109wm Fan Replacement, Fan: Schritt 11, Bild 3 von 3
    • Using a JIS #1 screwdriver, remove the five 5mm screws.
    • Detach the power button cable.
    • Detach the touch pad cable.
  12. HP Pavilion 15-b109wm Fan Replacement: Schritt 12, Bild 1 von 3 HP Pavilion 15-b109wm Fan Replacement: Schritt 12, Bild 2 von 3 HP Pavilion 15-b109wm Fan Replacement: Schritt 12, Bild 3 von 3
    • Using a plastic opening tool, pry open the top cover.
    • Unscrew the two 5 mm screws using a JIS #1 screwdriver.
    • Gently, pull to detach the fan cable.
    • Be careful so you do not damage the motherboard.
  13. HP Pavilion 15-b109wm Fan Replacement: Schritt 13, Bild 1 von 1
    • Carefully remove the fan from its slot.
Abschluss
UMass Dartmouth, Team S2-G2, Peak Fall 2018 Mitglied von UMass Dartmouth, Team S2-G2, Peak Fall 2018
UMASSD-PEAK-F18S2G2
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 471
