Zum Hauptinhalt wechseln
HP Pavilion 15-ba003ds Charging Port Replacement
Was du brauchst
  1. HP Pavilion 15-ba003ds Charging Port Replacement, Battery: Schritt 1, Bild 1 von 2 HP Pavilion 15-ba003ds Charging Port Replacement, Battery: Schritt 1, Bild 2 von 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: Schritt 2, Bild 1 von 3 HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: Schritt 2, Bild 2 von 3 HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: Schritt 2, Bild 3 von 3
    • Use a Jimmy to pry off the black backplate.
  3. HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: Schritt 3, Bild 1 von 2 HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: Schritt 3, Bild 2 von 2
    • Remove three black 6mm Phillips #00 screws.
  4. HP Pavilion 15-ba003ds Charging Port Replacement: Schritt 4, Bild 1 von 3 HP Pavilion 15-ba003ds Charging Port Replacement: Schritt 4, Bild 2 von 3 HP Pavilion 15-ba003ds Charging Port Replacement: Schritt 4, Bild 3 von 3
    • Unplug the white connector using your fingers or a spudger.
  5. HP Pavilion 15-ba003ds Charging Port Replacement: Schritt 5, Bild 1 von 3 HP Pavilion 15-ba003ds Charging Port Replacement: Schritt 5, Bild 2 von 3 HP Pavilion 15-ba003ds Charging Port Replacement: Schritt 5, Bild 3 von 3
    • Pull out the fan by hand.
  6. HP Pavilion 15-ba003ds Charging Port Replacement, Charging Port: Schritt 6, Bild 1 von 1
    • Use a spudger to disconnect the power cable from the motherboard.
  7. HP Pavilion 15-ba003ds Charging Port Replacement: Schritt 7, Bild 1 von 3 HP Pavilion 15-ba003ds Charging Port Replacement: Schritt 7, Bild 2 von 3 HP Pavilion 15-ba003ds Charging Port Replacement: Schritt 7, Bild 3 von 3
    • Remove two 8mm Phillips #2 screws from the metal plate.
    • Use your hand to flip the metal plate so you can see the charging port fully.
  8. HP Pavilion 15-ba003ds Charging Port Replacement: Schritt 8, Bild 1 von 2 HP Pavilion 15-ba003ds Charging Port Replacement: Schritt 8, Bild 2 von 2
    • Use a spudger to pry off the charging port.
Abschluss
LI XU
334 Reputation
2 Anleitungen geschrieben
York University, Team S1-G9, Woodhouse Winter 2020 Mitglied von York University, Team S1-G9, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G9
3 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
how much does it cost to replace a laptop charging port
Ebele Athekame - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 36
Insgesamt: 2,406
