Einleitung
This guide will detail how you can get into the HP Pavilion 15-ba003ds and replace the charging port by providing you the steps to follow.
You can follow this guide if your AC adapter is not charging the laptop and you’re sure that the AC adapter is not faulty. Then you can attempt this repair to replace the charger in your laptop.
Was du brauchst
Unplug the AC adapter from the corresponding socket in the laptop.
Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
Carefully slide the battery out of the laptop frame and place it somewhere safe.
Use a spudger to disconnect the power cable from the motherboard.
Remove two 8mm Phillips #2 screws from the metal plate.
Use your hand to flip the metal plate so you can see the charging port fully.
