Zum Hauptinhalt wechseln
HP Pavilion 15-ba003ds RAM Replacement
Was du brauchst
  1. HP Pavilion 15-ba003ds RAM Replacement, Battery: Schritt 1, Bild 1 von 2 HP Pavilion 15-ba003ds RAM Replacement, Battery: Schritt 1, Bild 2 von 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds RAM Replacement, Disc Drive: Schritt 2, Bild 1 von 1
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds RAM Replacement: Schritt 3, Bild 1 von 2 HP Pavilion 15-ba003ds RAM Replacement: Schritt 3, Bild 2 von 2
    • Remove twelve 8mm Phillips #00 screws including two underneath the rubber feet.
  4. HP Pavilion 15-ba003ds RAM Replacement: Schritt 4, Bild 1 von 2 HP Pavilion 15-ba003ds RAM Replacement: Schritt 4, Bild 2 von 2
    • Pull out the disc drive by hand.
  5. HP Pavilion 15-ba003ds RAM Replacement, Backplate: Schritt 5, Bild 1 von 3 HP Pavilion 15-ba003ds RAM Replacement, Backplate: Schritt 5, Bild 2 von 3 HP Pavilion 15-ba003ds RAM Replacement, Backplate: Schritt 5, Bild 3 von 3
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds RAM Replacement, RAM Module: Schritt 6, Bild 1 von 2 HP Pavilion 15-ba003ds RAM Replacement, RAM Module: Schritt 6, Bild 2 von 2
    • To release the RAM, hold and pull the strips outwards on either side of the RAM.
Abschluss
York University, Team S1-G9, Woodhouse Winter 2020 Mitglied von York University, Team S1-G9, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G9
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 291
