Zum Hauptinhalt wechseln
HP Pavilion 15-ba003ds Screen Replacement
Was du brauchst
  1. HP Pavilion 15-ba003ds Screen Replacement, Screen: Schritt 1, Bild 1 von 3 HP Pavilion 15-ba003ds Screen Replacement, Screen: Schritt 1, Bild 2 von 3 HP Pavilion 15-ba003ds Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Apply firm pressure and slide the metal spudger along the outside edges of the front panel screen.
    • When using the metal spudger, be careful not to press into the plastic panel too hard. It may damage internal cables or the panel.
  2. HP Pavilion 15-ba003ds Screen Replacement: Schritt 2, Bild 1 von 3 HP Pavilion 15-ba003ds Screen Replacement: Schritt 2, Bild 2 von 3 HP Pavilion 15-ba003ds Screen Replacement: Schritt 2, Bild 3 von 3
    • Continue sliding the metal spudger to the bottom of the screen.
    • Don't pull on the frame outwards as this will put pressure on the panel and damage it.
  3. HP Pavilion 15-ba003ds Screen Replacement: Schritt 3, Bild 1 von 3 HP Pavilion 15-ba003ds Screen Replacement: Schritt 3, Bild 2 von 3 HP Pavilion 15-ba003ds Screen Replacement: Schritt 3, Bild 3 von 3
    • Flip the laptop so the bottom is facing upwards.
    • Using the metal spudger, separate the plastic panel off the screen.
  4. HP Pavilion 15-ba003ds Screen Replacement: Schritt 4, Bild 1 von 3 HP Pavilion 15-ba003ds Screen Replacement: Schritt 4, Bild 2 von 3 HP Pavilion 15-ba003ds Screen Replacement: Schritt 4, Bild 3 von 3
    • Once the panel is separated from the screen, gently pull it off and set it aside.
    • Remove two 6mm Phillips #00 screws from the bottom of the screen.
  5. HP Pavilion 15-ba003ds Screen Replacement: Schritt 5, Bild 1 von 3 HP Pavilion 15-ba003ds Screen Replacement: Schritt 5, Bild 2 von 3 HP Pavilion 15-ba003ds Screen Replacement: Schritt 5, Bild 3 von 3
    • Remove two 6mm Phillips #00 screws from the top of the screen.
  6. HP Pavilion 15-ba003ds Screen Replacement: Schritt 6, Bild 1 von 3 HP Pavilion 15-ba003ds Screen Replacement: Schritt 6, Bild 2 von 3 HP Pavilion 15-ba003ds Screen Replacement: Schritt 6, Bild 3 von 3
    • Flip the screen down.
    • Remove the tape from over the connector.
    • Pull out the connector using your fingers.
  7. HP Pavilion 15-ba003ds Screen Replacement: Schritt 7, Bild 1 von 1
    • Lift the screen away from the laptop.
Abschluss
Joseph Chia
355 Reputation
3 Anleitungen geschrieben
York University, Team S1-G9, Woodhouse Winter 2020 Mitglied von York University, Team S1-G9, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G9
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 17
Insgesamt: 333
