Einleitung
Your stock hard drive could be too slow for your operating software. Use this guide to replace your current hard drive with one of larger capacity.
Was du brauchst
Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
Remove the two screw cover strips.
Remove the two screw cover plugs.
Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
Turn the computer over to the front.
Open the laptop.
Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
