Zum Hauptinhalt wechseln
HP Pavilion 15-ca2073cl Battery Replacement
Was du brauchst
    1. HP Pavilion 15-ca2073cl Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
      • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
      • Flip the laptop over.
      • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
      Frag FixBot
      Kommentar hinzufügen
    2. HP Pavilion 15-ca2073cl Battery Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-ca2073cl Battery Replacement: Schritt 2, Bild 2 von 2
      • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
      • Start from the front and work down both sides, disconnecting clips.
      • Remove the bottom case from the body.
      Frag FixBot
    1. HP Pavilion 15-ca2073cl Battery Replacement, Battery: Schritt 3, Bild 1 von 2 HP Pavilion 15-ca2073cl Battery Replacement, Battery: Schritt 3, Bild 2 von 2
      • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
      Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 32
Insgesamt: 2,568
