Einleitung
For this guide, you will be instructed on how to replace the display-pad on the HP Pavilion 15-ca2073cl. Before progression, be sure that the battery is off and the back cover is off as well.
Was du brauchst
Flip the laptop over.
Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
Use an iFixit opening tool to wedge in between the case and the body of the laptop.
Start from the front and work down both sides, disconnecting clips.
Remove the bottom case from the body.
Open the laptop like you normally would if you were about to use it and use a plastic spudger to separate the top cover from the bottom.
While lifting the top cover, undo the clip holding the keyboard cable in place and pull the cable out.
Remove the screws from the display to the frame of the laptop.
Remove the cables that connect to the motherboard.
Remove the screws surrounding the display.
Using the spudger, pry the display from the display pad.
