Zum Hauptinhalt wechseln
HP Pavilion 15-ca2073cl RAM Replacement
Was du brauchst
  1. HP Pavilion 15-ca2073cl RAM Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over.
    • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
  2. HP Pavilion 15-ca2073cl RAM Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-ca2073cl RAM Replacement: Schritt 2, Bild 2 von 2
    • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
    • Start from the front and work down both sides, disconnecting clips.
    • Remove the bottom case from the body.
  3. HP Pavilion 15-ca2073cl RAM Replacement, Battery: Schritt 3, Bild 1 von 2 HP Pavilion 15-ca2073cl RAM Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
  4. HP Pavilion 15-ca2073cl RAM Replacement, RAM: Schritt 4, Bild 1 von 3 HP Pavilion 15-ca2073cl RAM Replacement, RAM: Schritt 4, Bild 2 von 3 HP Pavilion 15-ca2073cl RAM Replacement, RAM: Schritt 4, Bild 3 von 3
    • Pull the silver tabs on either side of the RAM outward.
    • Pull the RAM stick out of its slot.
  5. HP Pavilion 15-ca2073cl RAM Replacement: Schritt 5, Bild 1 von 3 HP Pavilion 15-ca2073cl RAM Replacement: Schritt 5, Bild 2 von 3 HP Pavilion 15-ca2073cl RAM Replacement: Schritt 5, Bild 3 von 3
    • Pull the tabs outward on either side of the second RAM stick.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 254
