Zum Hauptinhalt wechseln
HP Pavilion 15-ca2073cl SD Card Reader Replacement
Was du brauchst
Einführungsvideo
  1. HP Pavilion 15-ca2073cl SD Card Reader Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over.
    • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
    Frag FixBot
    Kommentar hinzufügen
  2. HP Pavilion 15-ca2073cl SD Card Reader Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-ca2073cl SD Card Reader Replacement: Schritt 2, Bild 2 von 2
    • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
    • Start from the front and work down both sides, disconnecting clips.
    • Remove the bottom case from the body.
    Frag FixBot
  3. HP Pavilion 15-ca2073cl SD Card Reader Replacement, Battery: Schritt 3, Bild 1 von 2 HP Pavilion 15-ca2073cl SD Card Reader Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
    Frag FixBot
  4. HP Pavilion 15-ca2073cl SD Card Reader Replacement, SD Card Reader: Schritt 4, Bild 1 von 3 HP Pavilion 15-ca2073cl SD Card Reader Replacement, SD Card Reader: Schritt 4, Bild 2 von 3 HP Pavilion 15-ca2073cl SD Card Reader Replacement, SD Card Reader: Schritt 4, Bild 3 von 3
    • Use a spudger to flip up the retaining flap securing the ribbon cable
    • Remove the white ribbon cable from its connector.
    Frag FixBot
  5. HP Pavilion 15-ca2073cl SD Card Reader Replacement: Schritt 5, Bild 1 von 1
    • Remove the single silver 4.3 mm screw with a Phillips #0 screwdriver.
    Frag FixBot
  6. HP Pavilion 15-ca2073cl SD Card Reader Replacement: Schritt 6, Bild 1 von 1
    • Remove the SD card reader from the laptop.
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 561
