Einleitung
Use this guide to replace the touchpad of the HP Pavilion 15-ca2073cl.
Before you begin to replace the touchpad, make sure the laptop is powered off.
Was du brauchst
Flip the laptop over.
Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
Use an iFixit opening tool to wedge in between the case and the body of the laptop.
Start from the front and work down both sides, disconnecting clips.
Remove the bottom case from the body.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Once the battery is removed, use the tweezers to disconnect the smaller ribbon cable that is attached to the touchpad and motherboard.
Proceed to disconnect the larger ribbon cable that is attached to the touchpad and motherboard.
Using a screwdriver with a Phillips #00 screwdriver, remove the three screws on the metal touchpad bracket. Remove the bracket.
Using the tweezers, pull back the adhesive tape at the top of the touchpad.
Using the screwdriver with a Phillips #00 screwdriver, remove the two screws at the top of the touchpad.
