Einleitung
If your computer will not turn on and you know that this is due to a defective hard drive, this guide will take you through the steps of removing it on the HP-Pavilion 15-cc023cl.
Was du brauchst
Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
Using the iFixit opening tool, pry open and remove the back cover of the laptop.
Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
Disconnect the port connecting the battery and the motherboard and then remove.
Use a spudger to lift the latch that holds the hard drive cable in place.
4 weitere Personen haben diese Anleitung absolviert.
